Home › Forum › Ask A Member › K35 UPDATE! Thank you to…
- This topic has 3 replies, 3 voices, and was last updated 1 year ago by
John Gragg.
October 20, 2025 at 7:20 pm #300806
Hello to all,
In the words of famed newscaster Gabriel Heatter, “There’s good news tonight”!
I want to thank everybody that gave me some advice on this especially Tubs and Seakaye.
So I was able to verify compression on the motor today. I’m getting 60 on one side and about 63 or 65 on the other. I was pretty sure I would get compression because when I removed the exhaust manifold I was able to see a bright silver ring no scratches on the Pistons and the Rings compressed slightly when I pushed on them.
I put the Magneto on the crankcase and put the flywheel on setting the points the way tub said to and I have spark on both sides! Looks to be good strong Spark.
So the next is the carburetor. Does anybody have any advice before I open it up?
I’ve already dropped the lower unit and have been Hand cleaning and soaking With B12 chem tool To get all the Heavy grease out of the bottom end.
I’m having a hard time with how this water pump works. If it has a water pump, which would be piston style, I sure can’t find it.
As for cleaning it up I was planning on using some naval jelly on the jugs. Would you use anything else anybody?
Thanks again any other advice I would be more than willing to accept. I’m trying to get this running for a friend.
Best regards to all stay well
John Gragg
RIverside, CAJust starting in the hobby, please be patient.
48 Sea King 5hp GG9014A. Sold
49 Sea King 5hp GG9014A
48 Johnson TD20. Sold
49 Johnson TD20. Sold
54 Johnson QD15. Sold
55 Johnson CD12. Sold
57 Johnson RJE-19M
57 Johnson RDE-19October 20, 2025 at 10:12 pm #300808
The prop is your impeller. It pulls water out of the opening in front of it, forward motion and the prop pushes water into the opening behind it. Nothing to the carb, Only thing is the throttle barrel, that the lever is attach to, must be rotated to the proper position for it to slide out.
October 21, 2025 at 2:12 am #300809Another option is Evaporust, and it’s advertised as ph neutral. Consequently, it shouldn’t eat away any non rusty metal. I have only used it a few times, but so far it seems effective with patience.
Also, for carburetor advice, try taking pictures of how the parts are oriented and attached before you disassemble them. This is especially helpful is reassembly gets posponed for some reason.
October 21, 2025 at 11:19 am #300813Thanks! Yes, I (almost) always remember to take pics throughout the workday if I’m working on something new.
I will look for some Evaporust when I go purchase the naval jelly.
Thanks!
John Gragg
57 Johnson RJE-19M
57 Johnson RDE-19 -
