Home › Forum › Ask A Member › Update on pristine 50$ 9622a 9.5hp
- This topic has 11 replies, 7 voices, and was last updated 11 years, 5 months ago by
cajuncook1.
June 6, 2015 at 12:42 am #1691
well patience does bring joy !
it loosened up after 4-5 weeks of soaking the rings, gentle wacks on the pistons , openning it’s fuel ports and blasting in some engine fogging oΓ―l
and…. waitingI can now turn the flywheel with one hand, no screeching pistons are sliding in and out like a swiss Watch !! π
I will close it up and regasket the head.
any sealant needed here as I am using a Sierra headgasket ? I had asked for OEM gasket but clerk ordered me a Sierra π
I will change the impeller and try it out before messing with the funny carb. π
June 6, 2015 at 12:56 am #17672Just because it’s spinning doesn’t mean she’s ready to start!
My 12D10 was frozen, I got her moving and moving quietly. On the recommendations of some of the members here I pulled her apart and checked the rings. 4 of the 6 rings total were stuck in some form or another.June 6, 2015 at 1:51 am #17674I am not to experienced on that level of surgery so I can only run some engine cleaners or seafoam like mixes for now and hope for the best .
I’ll check points / iginition etc… the usual easy thingsJoining AOMCI has priviledges π
June 6, 2015 at 2:07 am #17675If you can remove any of the ports so that you can see into the cylinder, you can check the rings with a little screwdriver. You can push them, if they move they’re free and you’re (probably) good.
It’s not that hard to take them apart and get them back together after. You just need to keep track of the parts. There’s enough information here to help you out if you get stuck
June 6, 2015 at 12:44 pm #17692I will consider it but this engine is "like new" and I just don’t want start inspecting exhaust ports behind the exhaust baffle or pulling the carb and reeds
I’ll chance it for now with a good dose of engine tuners
thanks for comments …btw should I dab the headgasket with sealant ?
June 6, 2015 at 1:48 pm #17695A "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
This reply was modified 7 years, 11 months ago by
Tubs.
Tubs.
June 6, 2015 at 3:51 pm #17701..that is what I needed to hear π
when I fire it up I’ll feedback.
Darn it …. that was my winter 2016 project …. now I ‘ll need to find another engine to fic next winter
June 6, 2015 at 5:34 pm #17703Did you ever post a picture of this pristine motor? I looked back over your posts and don’t see one.
June 7, 2015 at 1:35 am #17723quote Mr. Asa:If you can remove any of the ports so that you can see into the cylinder, you can check the rings with a little screwdriver. You can push them, if they move they’re free and you’re (probably) good.It’s not that hard to take them apart and get them back together after. You just need to keep track of the parts. There’s enough information here to help you out if you get stuck
The 9.5HP motors like this don’t have the traditional port/exhaust covers, so not easy to look inside.
I woud do a quick compression check, and give it a go! Run it a bit and check compression again.
June 7, 2015 at 3:39 am #17726No, there is no sealer used on the head gasket.
