Home › Forum › Ask A Member › Unknown Muncie
  • #5022
    gouh86
      I have a new Muncie/Neptune motor, which I am unable to find any information on it using the serial and model numbers. I am in need of a set a piston rings and a owners/repair manual. The model # is 4B39X and serial # is 17341F4 any help you could give me I would greatly appreciate.
      #42378
        #42380
          2-1/16" bore – 1-½" stroke – 10.02 cubic inch piston displacement. 4 HP @ 3,000 RPM – Points set at 0.015" – Champion 514 Spark plug gap 0.025"
          Shear pin 0.156" Diameter Bronze rod 1-3/16" long – – Hope this helps
          #42401
          gouh86
            Thank you so much guys for the info it will help greatly.
            By chance any suggestions on where I could obtain a set of piston rings and a owner/repair manual for this
            particular motor.
            #42439
              Link
              http://www.ringspacers.com/ringcost.htm
