Home › Forum › Ask A Member › ultasonic cleaner
  • #2042
    billy-t
      I bought a small cleaner recently from HF, used a couple times, is it normal operation to run for 3 minutes and then stop? Timed cycle? or should it run until shut off cant find the directions, lol.
      Thanks
      #20338
      brian-grigsby
        Try this for the manual.
        http://manuals.harborfreight.com/manual … /03305.pdf
        #20339
        jpatti75
          Yes, the little one runs for three minute cycles.
          JP
          #20363
          billy-t
            Thanks
            #20368
            r-delawter
              You will like using your usc and will find many uses for it. Having a heated one really helps with the cleaning process.
              #20455
              tom-c
                Great for cleaning those brass fixed jets in the JWs and Lightwins! use hot water with a little vinegar and salt. Then rinse thoroughly.
                #20457
                r-delawter
                  quote Tom C:
                  I have used vinegar it’s self so I will try it with adding a little salt.
                  #20461
                  billy-t
                    I haven’t really had any great results, the three minutes cycles on my unit seems rather useless. I have been using pine-sol and water, will try vinegar and salt.
                    I likely should have bought the one that runs for longer cycles. What would be a reasonable time to clean a carb for example?
                    #20465
                    r-delawter
                      I have a longer timer on mine and I leave some carburetors in 1/2 hour or more.
                      Pine-sol will discolor some things. I would think the vinegar solution will too. Its important to know what the various solutions will do to different metals before using them. I have cleaned lots of carbs in a soap solution using ( awesome ) and water. It does a good job much of the time and has been non corrosive for me. I purchase it at the Dollar Store. Other folks will chime in with other good things to use.
                      #20466
                      r-delawter
                        You can also do a Google search on ultrasonic cleaners and learn a lot.
