Home › Forum › Ask A Member › Type of wire
  • #4105
    Goman
      What type of wire or equivalent do I need to find to re secure this screw? It’s for a ’29 Lockwood Chief.
      I have some different types of wire around but I figured I ask first before I use something I shouldn’t. 😕
      Thanks for your help.
      Glen
      #35236
      ADAM GIBB
        Glen,
        That is lockwire, used mostly in the aviation industry today. It is usually stainless and comes in a few different gauges. I am not sure where it can be bought. I got some rolls when I bought a tool box from a retired aircraft mechanic. You might try grainger or Fastenal.
        Adam
        #35240
        PugetSoundBoater
          Stainless safety wire is used on most critical aircraft fasteners. You should be able to get it at stores like Adam said .Special pliers are made for twisting it real tight ,guess you would call them safety wire pliers. I had never seen them before I started working on hydroplanes. I’ve thought about using safety wire on the lower unit attaching bolts ,as a friend builds racing outboards and he uses it in a few places on his motors .
          Robbie Robertson
          #35243
            Home Depot, Can Tire, Princess Auto, those types of stores carry small rolls of stainless wire along with brass, aluminum, galvanised etc.
            #35251
              were they really using stainless wire in the old days
              with all that grease galvanized wire should last 100 years… no ?
              #35260
              Doug Wilson
                all of the safety wire I have used has been stainless I know McMaster Carr has it and the pliers that lock on to twist it. Grainger and Fastenal should have it too. Standard wire will usually break before you get it tight.
                Doug
                Doug
                turned off?
                #35286
                Goman
                  Thanks guys There’s a Fastenal near me I’ll see what they have if not I’ll order something else. I’m beginning to learn to use the right part or pay heck.
                  #35289
                    Clean and dry threads coated with Loc Tites Red Hi Strength Thread Locker or something similar should eliminate any need for any safety wires on a threaded part. In the old days, they only had bailing wire and good luck to keep their machinery from coming apart under load.No duct tape back then!
                    #35298
                    marty-a
                      The aircraft industry safety wire is ( was ) monel . Much stronger than stainless. If you cannot find any let me know and I will send you a few feet. Marty
                      #35302
                      Goman
                        If I had to buy one of these things I would be Twisting and Shouting. 😮
