Home › Forum › Ask A Member › Two stuck flywheels
- This topic has 17 replies, 14 voices, and was last updated 11 years, 5 months ago by
49hiawatha.
May 29, 2015 at 9:57 pm #17159
If you’re going to heat the flywheel, take some parafin wax and melt a small amount on the shaft. It will creep down into the taper.
May 29, 2015 at 10:51 pm #17160I had one so stuck on a JW, that it took me on a 3 foot cheater bar holding the flywheel, and another person on ANOTHER 3 foot cheater bar, just to get the flywheel nut off. Let’s just say the lbs per square foot applied to that sucker was WAY above what it should have required to pull the flywheel nut. It had to have been 200 ft lbs+ holding the nut on.
May 29, 2015 at 11:09 pm #17162Last one I had that was a PITA I tightened the puller as much as possible, smacked the side of the flywheel with a wooden mallet a couple times, rotated it 90 degrees, tightened as much as possible and hit it, kept doing that. Eventually it popped.
By the end I was having to use my electric 1/2" impact to tighten the central pulling bolt.Hit the side of the flywheel, don’t hit the top. The vibrations from the impact are what you want.
Also, the majority of other pullers that people are going to use are likely to be automotive designed. Way overbuilt for what you’ll normally see in outboards usage. I doubt you’ll see any deflection in them. There can be a problem with the bolt size not fitting in the slots for the automotive style pullers, but that’s easily fixed.
May 30, 2015 at 1:13 am #17167quote Mr. Asa:Last one I had that was a PITA I tightened the puller as much as possible, smacked the side of the flywheel with a wooden mallet a couple times, rotated it 90 degrees, tightened as much as possible and hit it, kept doing that. Eventually it popped.
By the end I was having to use my electric 1/2″ impact to tighten the central pulling bolt.Hit the side of the flywheel, don’t hit the top. The vibrations from the impact are what you want.
Actually, don’t hit the side of the flywheel either, nor the top. Just the puller bolt.
May 30, 2015 at 2:27 am #17170I’m with Don, get a hold of an OMC factory puller, they are superior to the cheaper ones. Steering wheel pullers will bend or deflect enough to not do the job. You can also use it to lift motors with the available lifting eye.
May 30, 2015 at 5:43 am #17185quote Mr. Asa:.Hit the side of the flywheel, don’t hit the top.
Not really the best idea as you can knock the magnetism right out of the magnets.
May 30, 2015 at 12:06 pm #17188I think if you have cracked or blew out the crank shaft , your method may be in error. I have never seen a crankshaft fail with the nut left on the crank even with the top after it has been loosened. As mentioned earlier place the nut back on crank, even with top of crankshaft. Then place the puller.
May 30, 2015 at 12:31 pm #17189I found a reference to the "knocker" that Chris P suggests on the old board w/pictures. I suggest you use Grade 8 bolts/nuts and it has worked slicker than grease for me…
