Home › Forum › Ask A Member › Two questions on a 3HP Johnson
  • #271382
    billy-t
      Good Afternoon
      I have a couple questions that I am hoping you fellows may be able to help me with.
      1. I am working on a 1962 Johnson 3hp and was going to pull the fuel peacock and filter but the filter stayed in the tank when I turned out the fuel fitting.  So I am guessing what ever held them together originally deteriorated.  So can I use a punch to gently knock the fuel filter out and  reattach to the fuel fitting by soldering or some other method?
      2. in the Carb kit 0439071 you get two plastic O-rings/washers to use on the high and low speed needles and the packing washers.  Would anyone be able to tell me a size of this oring/washer and a source if there is a  place to buy a bunch.
      Thanks for any help provided.
      Bill
      #271391
      Steve D
        Yes, I believe soldering is the best way to re-attach that and I think Mumbles commented on that not too long ago. But I’ve also seen some that were secured with what I believe was 3M 847 or similar, that showed no sign of leakage. As far as the nylon washers that go on after a couple of the cork packing, I’ve gotten them from McMaster Carr and they’re a perfect substitute.
        https://www.mcmaster.com/catalog/129/3630/95606A420
        Part #95606A420
        Nylon Plastic Washer, Number 12 Screw Size, 0.25″ ID, 0.375″ OD, 0.026″-0.036″ Thickness
        carb-packing-nylon-washer-comparison-and-prices
        • This reply was modified 3 years, 9 months ago by Steve D.
        #271409
          you if the tank filter element  is a problem to fix  you can always install a small fuel line filter between the valve and the carb inlet . the small  red ones used on  lawn mowers should  be fine anddo not take up much space.
          Amazon.ca : mower fuel filters
          #271413
          billy-t
            Thank you for the information , greatly appreciated.
            #271415
            billy-t
              Unfortunately, McMaster Carr does not ship to individuals in Canada, only businesses and schools.  Have to find another source for those washers!
              #271423
              Steve D
                Bill, Sent you a message.
                #271481
                  When the filter breaks off inside the tank, I’ve removed them by first tapping them and then using a bolt with a nut to draw them  out. Once the parts have been thoroughly cleaned, a good epoxy can be used to hold them together.
                  As far as the plastic washers for the needle packing go, your motor didn’t come with them, as later models did, so I wouldn’t worry about it if they aren’t used. It seems to me the brass gland nuts are a slightly different style to for use with the plastic washers. By that I mean the way they are machined on the inner contact surface.
                  DSC00014
                  DSC00013
                  DSC00017
                  DSC00018
                  • This reply was modified 3 years, 9 months ago by Mumbles.
                  #271491
                    Some more photos.
                    DSC00019
                    DSC00001
                    DSC00003
                    #271496
                      I don’t know what’s going on but those are NOT the photos I chose! Oh well, enjoy!
                      That was the second time it happened but at least the thumbnails are correct.
                      #271503
                        Same thing happened to me last week posting photos.
                        Some Mercury loaded on the screen when I was posting
                        Champion photos…… strange thing is, I don’t think the
                        photos were even from my hard drive!
