Home › Forum › Ask A Member › Two line gas connector
  • #2334
    joellerich
      I need to replace the "O" rings on a two line fuel system. I have the old "O" ring removed. It came out in pieces. What is the proper size "O" ring to use as a replacement.
      Thanks
      John
      #22532
      wiscoboater
        You will want to buy the real BRP Orings. Do NOT buy the cheapo ones from Sierra. They don’t fit right and tend to leak the day you put them in. Buy these,
        BRP part # 0301824 Part # 2 in diagram
        http://www.marineengine.com/newparts/pa … OMC0301824
        http://www.marineengine.com/parts/evinr … L-TANK.gif
        #22638
        joellerich
          Thanks for the info.
          John
          #22642
            There are some other sources for them
