Home › Forum › Ask A Member › trying to find new coils for a HD-20
  • #256909
    Hugh Davis
      Good morning all
      Can anybody direct me to where I can find a pair of new coils and points for an HD-20
      Thanks,
      Hugh
      #256923
        Pretty sure no one is reproducing either, so you’ll have to find good used
        or make do with what you have.
          Would that be 375189 coil and 580016 points?  marineengine.com has both for about the value of gold.
          #256932
          Hugh Davis
            Bucky and Frank, Thanks!!
            I have the name of the guy in SW Windy City, maybe he can help rebuild or………….
            I am also looking for some spark plug wire. AOMCI turned me onto a guy who has 3 or 4 colors of 7MM  ignition cable for I think I remember about $1.95/foot
            but I can’t find the name of the guy. might you know who sells new wire?
            #256933
            Hugh Davis
              Found him
              Otto ringspacers, $1.50/foot
              in MD
              #256946
              aquasonic
                Have you tested the coils. Most of the time the original coils are fine. As long as they test OK with an ohmmeter, the purchase of ridiculously expensive NOS coils doesn’t make much sense. If you want new ignition wires, they will need to be soldered on regardless if the coils are new or used. Soldering is a little tricky, if your not experienced at it, and the coil can be ruined from too much heat.
                Improvise-Adapt-Overcome
                #256957
                Dale
                  Guys are you talking about the push rod points?   I have a backing plate complete with good coils from a 1950 Evinrude 14hp.  Is that the same as an HD20?    They seam to throw good spark in my tester.
                  Hugh if you think you can use what I have send me a PM.  I will send them to you.
                  dale
                  #256964
                  fastjohn
                    I have a few NOS #580016 in the original box for $10 plus shipping.  PM me
