Home › Forum › Ask A Member › Trying to decide on a boat for engine testing, transom cut down ?
- This topic has 9 replies, 5 voices, and was last updated 6 years, 4 months ago by
ROBERT LAFAYETTE.
June 23, 2020 at 9:48 pm #206544
I can get this mid 70’s 14′ starcraft for a fair deal and I boat on the Ohio river often as i live a block away so beam and higher free board is nice, speed is fairly low priority. Most of my engines are all short shaft, tiller and remote both. Has anyone cut down or replaced a transom in an aluminum boat from 20″ to 15″ format ?? I really like the old Alumacraft 14’s for vintage stuff, and valco and gregor for looks but their lower sides and more rounded bottom is just less stable for this old guy. I have had a few older v hulls over the years and thinking this would be more enjoyable to use although not as nostalgic. I have a several old engines all in the range currently from 1.5 to a 54 model 25 hp evinrude and wanting to find a good 55+ 35hp as well. Any thoughts on the proposed modifications.
I got a few I have had a long time but can always use a few more going into retirement.
This topic was modified 6 years, 4 months ago by
Mumbles.
June 24, 2020 at 6:55 am #206554Ever had to go downwind in a heavy chop ???? I would not cut down the transom for simple safety reasons
June 24, 2020 at 11:48 am #206567An Alumacraft FD or similar is deeper, has a splash well on the short shaft transom. If you cut it down, you need to add a splash well if you are concerned about getting swamped.
June 24, 2020 at 1:32 pm #206581I do really like the FD’s but continue to fail to find one that is not either butchered, too far away as in 6+ hours or without a title or no reply’s from seller. I do also like the splash well on any 15″ transom boat I use in my waters.
June 24, 2020 at 3:07 pm #206585If you do not want to cut the transom, consider a small jackplate that can be unbolted and removed when using your longshaft motor. https://bobsmachine.com/product/mini-manual-jack-plate-mmj-0-40-hp-max-for-clamp-on-motors/
June 24, 2020 at 7:31 pm #206606Trying to get ahold of a guy on this boat. Looks like an Alumacraft FD but only has one set of oar locks ?? Seems odd. Has the aquaduct transom and stated as 14′ with the higher sides. ?? Any ideas ??
This reply was modified 6 years, 4 months ago by
Doug.
June 25, 2020 at 7:52 pm #206704I would not cut down the transom on any boat. Hurts resale value and maybe strength?
I would suggest a SEA NYMPH 14R “R” stands for Rough water
Or a CRESTLINER 1460 – 1468 with 15″ transom height.-
ROBERT LAFAYETTE.
ROBERT LAFAYETTE.
June 25, 2020 at 10:26 pm #206733Trying to get ahold of a guy on this boat. Looks like an Alumacraft FD but only has one set of oar locks ?? Seems odd. Has the aquaduct transom and stated as 14′ with the higher sides. ?? Any ideas ??
Doug.
It looks like an FD to me, they may have deleted a set of oar locks on newer models.
June 25, 2020 at 10:42 pm #206734Lots of research since I asked this, ya I know I was bored !! , I have found 2 more boats with the forward oarlocks missing and no obvious evidence of removal. in one case it was equipped with the full width aluminum steering dash and it sit right where the forward oarlocks were. maybe they were omitted when this option was added, i don’t know, just no mention in the old brochures, the other was just also missing the forward set. I heard back on the one and I am buying it, it was in fact tagged as an FD and has a 1968 title. I think this boat is the right combination for water and engine range capable and is a vintage to seem right when running my 50’s- 80’s OMC’s I wanted the wider at the bottom rear but in the end do not like the looks nearly as well so gotta go with what looks fun since it is a big toy.
Thanks for the info on those other two models, I like all of the high side low transom designs but am extra attracted to the FD splash well for my use.
Doug.
July 9, 2020 at 4:22 pm #208185Doug,
Check this ALUMACRAFT out maybe a 1994 same as my T12S
Deep and Wide, with a 15 ” transom. looks to be in good shape
This boat would cost $4000.00 new.https://sandusky.craigslist.org/boa/d/sandusky-14-alumacraft/7152152510.html
