Home › Forum › Ask A Member › Trouble pulling Motor Cover on Johnson QD 10
  • #265803
    RickV
      Hi,  I am having trouble pulling the one side of a 1949 Johnson QD .  Only 1 knob stands in the way of removing this side.  Do I get plyers and just turn it LEFT to unscrew or possibly try and pull it straight out toward me to remove knob ?  (I’m new at this)
      Thanks for any help
      #265806
      LLOYD LAUTNER
        If I remember correctly a screw holds the knob on it’s shaft. Loosen the screw and the knob will slide off the shaft. Then when the side cover is loosened from it’s mounts it will come forward to clear the shaft.
        #265807
        RickV
          Hi Lloyd, Thanks for answering ,  If I am understanding you correctly, your saying the knob has a screw , but there is no screw on the knob.  (You can see from the pic, no screw on knob)
          LLoyd you were correct,  my fault, didnt see the screw on the knob until I  turned it all the way.   Thanks again
          • This reply was modified 4 years, 1 month ago by RickV.
          #265811
          elgin2
            Is there a set screw on the side of the knob?
            #265812
            CHUCK
              Knob1
              On my QD-10,  the Enrichener knob has a set-screw that tightens down on the shaft.
              • This reply was modified 4 years, 1 month ago by CHUCK.
              #265816
              RickV
                Ah,  Thanks so much,  did not see that untill I turned the knob……..Appreciate it and your time……
                #265817
                RickV
                  Lloyd,   You were correct,  my fault,  did not see that screw on the knob until I turned it.   Thank you again for answering
                  #265819
                  RickV
                    Everybody that answered,  Thank you.   Really appreciate,  problem solved
