Home › Forum › Ask A Member › Transom
- This topic has 19 replies, 11 voices, and was last updated 6 years, 8 months ago by
jerry-ahrens.
March 4, 2020 at 7:35 am #196600
Working on my transom for my alumacraft model f. Is it advisable to put a piece of metal over the inside transom wood where the screw clamps contact ? I was thinking to keep the wood from crushing. Thanks.
March 4, 2020 at 7:43 am #196601It makes sense to me – Some 1/8″ aluminum or stainless steel, where the clamp is.
It would stop the point wear from the clamps, as well as help spread the load.
Just don’t use pressure treated wood – But you knew that ….March 4, 2020 at 8:37 am #196609Sure did! Oak on the outside and marine plywood on the inside. All coated with spar urethane and stainless fasteners.
March 4, 2020 at 9:19 am #196618when I redid and raised a transom to 20 inches …..years ago for my Merc Is used some bar stock U channel (appox 1/4 thick)
I notched two ” clamp wide” notches off set from center by about 2 inches
Bolted up the bar stock on the transom under the clamps dead center on the boat’s new wood transom
the two notches .. being off-set allowed me to install the engine on my new transom bracket and I then slid the big guy sideways to center it on the transom bracket
the engine clamps now secured under the remaining “lip” provided extra security in case they ever loosen up a bit
The “bottom” edge can be cut/removed….. on better yet you can use a L channel bar stock or angle bar stock and cut out the notches in the lip. trim down the edge of the lip if to wide
p.s no I did not submit for a patent 🙂
This reply was modified 6 years, 8 months ago by
JACQUES.
March 4, 2020 at 10:37 am #196629
March 4, 2020 at 11:18 am #196634March 4, 2020 at 8:16 pm #196674somebody modified my non-registered patent 🙁
March 5, 2020 at 8:24 am #196723It makes sense to me – Some 1/8″ aluminum or stainless steel, where the clamp is.
Just don’t use pressure treated wood – But you knew that ….Newbe question:. What’s the issue with treated wood?
March 5, 2020 at 8:49 am #196725Reacts with the aluminum and eats holes in it.
March 5, 2020 at 8:54 am #196726Thanks frankr! That’s why they pay you the big bucks! They dont let me out much so I’ve never seen them!! Lol bryan.
