Home › Forum › Ask A Member › Transom Wood
  • #6563
    slim60
      I have a ’53 Alumacraft that needs the rotted wood replaced. What kind of wood was used originally?
      #54519
      opposedtwin
        White oak on the inside and plywood on the outside. Can’t recall what thickness the plywood is but others will know. I believe it should be replaced with marine grade plywood.
        What model is it? Thickness may depend on that.
        #54522
        fisherman6
          I’m replacing mine right now in my 14 foot Alumacraft. I think mine is an FD, but no number so I’m not certain. The thickness of my inside board is 1.06" it’s supposedly a 5/4 white oak board but I had my rough sawn board planed to 1.15" and it’s still too thick to go under the cap and the Aqueduct braces won’t fit yet. I didn’t have my original board out yet whenot I bought the replacement. They may vary a little by Model. I have a Flying C that will be getting replaced at some point too, but not yet. 3/8 Marine plywood on the outside of bother of my Alumacrafts. My wood guy didn’t have any 5/4 white oak either so I’m going back in with hickory in the FD.
          -Ben
          OldJohnnyRude on YouTube
          #54534
          jerry-ahrens
            The other thing that Alumacraft did was to ad a layer of cork under each board, [inside and out] to cut down vibration, and for sealing. If done correctly, you won’t need any sealer around the fasteners.
            #54538
            oopzdoo
              I have been using Mahogany deck boards bought at my local lumber yard. It is around 5/4 by 5 1/2 inches and fits in nicely. I have used I/2 inch cdx on the outside. I use polyurethane on the board and sealer and good oil base deck paint on the plywood. Looks good and has plenty of strength. Don’t be afraid, the cost for the mahogany is very reasonable. And the job looks good for years. Just my .02 worth.
              Dave in N.H.
              #54540
              vixbit
                Marine plywood does not have any voids in the inner plys plus the glue is waterproof. Cdx plywood will have voids in the inner plys and the glue is water resistant not water proof. For my money if you are going to take the time to replace it use the correct material and it will last another 50 years.
                #54548
                Randy in Tampa
                  I agree in using nothing but marine grade when using plywood on my boats 😎
                  quote vixbit:
                  #54550
                    I’ve used 2 …sandwiched 2 layers (2×3/4") of a special 7-8 ply water proofed plywood for porches I pre coated all inside and outside surfaces before fitting it in .. never had any problems after with a Merc Classic 50 in the back
                    #54575
                    slim60
                      The tag is hard to read but looks like an E. 12 feet with 3 flotation seats. 1/2" outer and 1" inner boards. White oak and marine grade plywood is what I’ll use. Thanks…Slim
                      #54576
                        quote crosbyman:
                        I’ve used 2 …sandwiched 2 layers (2×3/4″) of a special 7-8 ply water proofed plywood for porches I pre coated all inside and outside surfaces before fitting it in .. never had any problems after with a Merc Classic 50 in the back
                        What would some sources to finding some of that.
