Home › Forum › Ask A Member › Transom clamp
  • #272589
    Boonie
      It’s from a 1956 Javeline. I was able to remove them with a little force.
      #272602
      Boonie
        Has anyone tried the candle wax method?
        Apparently if you heat the area hot enough for the candle wax to melt when touched to the screw it will travel in and free things up. Read it somewhere. Never tried it.
        #272629
        JOSEPH BRINCAT
          Good that you were able to get it out.
          But just a word of caution about using heat on an aluminum to aluminum joint like the  OMC clamp screws…. heating will tend to encourage galling… think micro welding.
          The thread file is the way to go.
