Home › Forum › Ask A Member › transmission for 1947 Chris Craft 19 ft deluxe run about
  • #297771
    Tmil
      I have a 1947 Delux 17 ft run about made by Chris Craft.  The transmission has been adjusted as far as it will go.  I am trying to find a replacement or someone who might be able to repair it etc.  The engine it attaches to is a 6 cylinder Hercules.  Until I can find a solution this old girl is laid up!!!!
      #297779
        Mostly outboard motor guy’s here. I searched “Chris Craft boat transmission repair service “ and this came up. “ For Chris Craft boat transmission repair service, you can turn to specialists like Federal Marine Transmissions, known for rebuilding Paragon and Velvet Drive transmissions. Great Lakes Skipper also offers a wide selection of new and rebuilt boat transmissions, including those for Chris Craft. If you’re looking for parts or information, Chris-Craft-Parts.com may be a helpful resource.”
        #297790
          Not that hard, just new  to you.
          #297791
            Yhere has to bw someone who  has tranny experience out there, I built 3 & 4 speed auto trannys before. Bet it has three gears, forward, reverse idler & reverse or planitary set up for reverse with a drum brake for reverse rotation. Photos please!
            #297792
            JOSEPH BRINCAT
              Tmil… tell us where you are located. what were the symptoms of the failure?  and who made the evaluation of the trans? Mechanical transmission, perhaps just need bearings and seals, unless we are talking catastrophic failure.
