Home › Forum › Ask A Member › Trailering your antique boat with a antique outboard
  • #256505
    hondaatc
      Hey fellas I’m not new to boats but i am new to trailering a outboard without a tilt lock or without power trim so i picked up a 1961 johnson 40 hp for my 1962 mirrocraft runabout aluminum and it has no tilt lock (when i say tilt lock my 15 hp gamefisher has a lever to lock the outboard in the tilt position ) so no lock and no power trim to keep it tilted when trailering so my question is what does everyone else do ? I’m not comfortable towing it with engine down its pretty close to the road i have seen the transom saver rods but i figured id ask the experts thanks in advance
      #256506
      JOSEPH BRINCAT
        Yes, Transom saver rod, is the way to go.  I use one on my  (heavy) 1961 75 Evinrude and also on my 1957  35hp Evinrude.  Both set-up have the butt end of the rod fixed to the trailer rear cross member.
        #256507
          Yes, use a transom saver support bracket.
          1982 Evinrude 25hp
          #256514
            A tilt lock is going to stress the transom, especially on
            some of the roads to some back water launch’s.
            I use a motor toter  even with my 3hp Johnson.
            I figure the farther I can get the skeg from the black top
            the better.
            #256538
            lindy46
              Transom saver
              IMG_20211006_150821
              #256565
              reivertom
                I trailered my 35 Johnson for years with a 3/4″ board holding it up with a bungie cord hooked to the board. I’d turn it all the way to one side, put the board between the motor and transom clamp, I had a screw eye on the other side, and stretch it over the top and hooked it to a screw eye on the other…….very simple… I then held it all down from bouncing with another bungie to the boat.. I never had it flopping around , and it didn’t hurt a thing. If you have an old boat, make sure the transom isn’t rotten, especially if it’s a fiberglass. You can’t see the rot because it’s sandwiched between the glass. I found mine was gone and barely got by without a disaster.
