Home › Forum › Ask A Member › Trailer id help
  • #282983
    MarkD
      Just picked up this 1956 Crestliner Voyager on a solid trailer, but no markings on it. It is quite solid but I can’t find any other like it. Anyone have an idea of who made it?
      Mark
      #282995
        No idea on the trailer, but you got a nice boat!
        Mine is a 1957 “Viking” model.
        DSCN9411
        JOSEPH BRINCAT
          As for the trailer… looks kinda’ modern. Not a tilt trailer, correct? Tilt feature might indicate older late 50’s early 60’s . I do like the jack, appears to be a fast acting type that has a gear rack on the leg… like that kind, I have one on my 1957 Pamco trailer. A lot less cranking than the screw type.
          #282998
          MarkD
            Trailer doesn’t tilt, but has some odd wood pieces on the center rail at the end of it. A wood cross piece with large bolts and then the tongue piece is extended with a solid piece of wood. Jack is nice and works well.
            #283004
            Dale
              Mark. your trailer is a puzzle to me!   It has EZ loader rollers, left handed winch.  The axle is too far to the rear.  It might be a mix and match outfit! but…if it works it’s good!
              dale
