Home › Forum › Ask A Member › Top speed with 18hp Evinrude on 14′ aluminum
Viewing 10 posts - 91 through 100 (of 106 total)
  • #53320
    stephenspann27
      I think this powerhead had fairly low hours on it, the cross hatching in the bores is still there. Something lead to ti’s desmise, overheating or lack of lubrication. The thermostat was missing when I got the motor. Might be a clue..
      #53325
        When you remove the thermostat, the water follows the path of least resistance. This means most water bypasses the water jacket making the outlet feel very cool. The motor however, is usually getting less and running very hot.. . 🙄
        #53326
        stephenspann27
          quote Garry in Tampa:
          Agreed, and the water flow through too fast to really draw out much heat. I put a thermostat in it before I ran it.
          #53334
            Smaller motors such as a 6 and 9.9-15 are the opposite and will run too cold without a stat and start fouling spark plugs.
            #53341
            stephenspann27
              I wish I had a good test tank where I could put a load on the motor and watch it with a infrared gun.
              #53345
                Garry,
                Thank you so much for the tip on the stat, I own a 58 18hp Johnson & I like it very much!
                Jeff
                #53346
                wiscoboater
                  One word of warning Stephan, do not try to run at speed in a barrel or garbage can. Idle only with a couple quick jabs of throttle. Get your motor to where it will stay running in the barrel but do your tuning on the lake under load. Adjust high speed first. Then go back and re tweak the idle. Good luck with the new powerhead.
                  Jeff
                  #53570
                  stephenspann27
                    I’m able to get 19mph now with a new to me powerhead from wannabee.
                    #53572
                      How steep is the prop on this motor? Numbers should be under the prop nut.
                      #53575
                      stephenspann27
                        quote Mumbles:
                        Prop is 9×10. I’m getting about 4,300RPM. Max HP is 4,500rpm according to the cowl, but operating range is up to 5k.
