Home › Forum › Ask A Member › Tool for making OMC carb needle packings
Viewing 10 posts - 11 through 20 (of 23 total)
  • #326518
    fisherman6
      I’m glad my video was found.  I do not have any of these punch tools left at this time.  I may get time to get a few sets made this fall/winter.  I’m not sure what the cost will be yet.  Material has gone up a lot and available time has gone the other direction.
      I use Fel-Pro 1/16″ gray rubberized fiber gasket material to make the packing washers. It seems to hold up well and work very much like the OEM pieces.  I have tried other gray fiber gasket material and while it works, it seems to be more prone to breaking apart. I have not tried their blue fiber gasket material to see how it works.  It seems reasonably well-suited to the task.
      -Ben
      OldJohnnyRude on YouTube
      #326521
      JOSEPH BRINCAT
        Dale, that is a great idea… ingenious and best of all employs standard tools and materials.
        #326522
          Dale is a genius!!!! Who Knew.
          #326529
          CHUCK
            Dale;  I KNEW there was a reason I’ve kept that old mower!  I just checked and it has the perfect donor flap….nearly intact!
            #326535
            outboardnut
              Dale
                I hope it works for you.  Those packings are a pain for sure!  No genius here, just and old dirt kicker, wanna be a boat house mechanic.
                dale
                #326574
                Steve D
                  I bought one of Ben’s packing tools a few years ago and I love it. (I use it on a flattened out cereal box and it seems to be easier on the blades than on wood).
                  But whatever method you use to make them it’s a good idea to use the nylon washer that came with the kits. I don’t know if they were included in the earlier kits because they don’t show up in the parts diagrams until the 70s I think. But using them between the packing and the nut helps to keep the packing from getting damaged too much. And it creates a nice smooth feel when adjusting too.
                  Pg.08-FD-11
                  1975-6-HP-carb
                  Carb-kit-439071-and-nylon-washers
                  #326583
                  outboardnut
                    To Steve D
                    Did you buy 100 of the 306027 ??
                    #326596
                    Steve D
                      fastjohn
                        I would like to buy 10 of the McMaster Carr nylon washers.  How do I contact you?  Thanks
