Home › Forum › Ask A Member › TN series petcock leak
- This topic has 14 replies, 11 voices, and was last updated 3 years, 5 months ago by
reivertom.
May 14, 2023 at 12:15 pm #276198
Hi there, I have a few tn28s I’m working with. One of the runners drips fuel from the tank cutoff and another one leaks just a bit. I’ve tried everything to stop the leak but no luck. The other valve stems I’ve tried leak the same way. What am I missing? I’ve tried o rings in the compression nut as well as rubber washers.
May 14, 2023 at 5:48 pm #276209Some of those petcocks shut-off stems have a thin metal washer, with
an original seal behind it. They can be a pain to get apart, but I’ve had
some luck replacing the original rubber seal with a O-ring, if you can
find the right size.Prepare to be boarded!
May 14, 2023 at 6:10 pm #276210Thanks for that. There is a small washer on the stem so perhaps I need an o ring that fills the entire cavity? The ones I have tried are rather thin. They don’t leak much while running its while its sitting that it has a slow leak into the carb.
May 14, 2023 at 7:15 pm #276211I’ve had luck with wrapping cotton string around the stem as a packing.
May 14, 2023 at 8:23 pm #276216Do you mean like kite string? There’s not much room on there but I can see that working. I just tried a modified rubber washer and it dripped once in about an hour. Much better. Maybe I should add the string.
May 14, 2023 at 8:54 pm #276217I have heard that winding dental floss round the stem will fix the leak.
May 14, 2023 at 9:00 pm #276218May 14, 2023 at 9:52 pm #276223Do you mean like kite string? There’s not much room on there but I can see that working. I just tried a modified rubber washer and it dripped once in about an hour. Much better. Maybe I should add the string.
Never thought of a kite, but yeah, probably. Haven’t flown a kite in the last 70 years, but some people have told me to.May 14, 2023 at 11:19 pm #276226Valve stem packing from the hardware plumbing section. Either the new teflon stuff or the old style graphite yarn. Or make your own from teflon plumbers tape by rolling the tape into a string. I would caution against using random “rubber” material, could be affected by the gasoline.
May 15, 2023 at 8:27 am #276228Make sure you get the YELLOW teflon tape, not the WHITE. The YELLOW is designed for gasoline.
