Home › Forum › Ask A Member › TN 28 – wet plugs
- This topic has 13 replies, 9 voices, and was last updated 10 years, 11 months ago by
jerry-ahrens.
September 14, 2015 at 2:58 am #2530
Hey all, awhile back, I started trying to revive a TN28. In the process on my work, I noticed that the engine had low compression, (45lbs), and it wouldn’t run on the lake for more than 45 seconds at a time. I figured that I had a bad head gasket and it was overheating, so I tried to replace it, and in the process, I sheared off most of the head bolts. I boogered up the powerhead trying to remove the broken bolts, I so I found another powerhead on EBay (with good compression), and attempted to run with that. I assembled the motor using the other components from the old engine. Now when I try to run the engine, it pop and smoke but it never runs. It seems to me that the engine seems to flood out easily, because when I pull the spark plugs, they are wet. I installed a Sierra tune up kit (new points and condenser) but the engine still floods out easily, and it has never run for more than 2 – 3 seconds. The coils are recently new as well. I never had trouble with the carb or ignition when I had the old powerhead. I took the engine out in the dark last night and tested the plugs by grounding them to the tank mount and they both give off a consistent blueish / white spark. Is it possible to install the magneto plate wrong? Also, when you pull the lever to the stop position, is the mag plate supposed to ground out, or does the plate retard the ignition so much that the engine doesn’t run? The reason I ask, is that when the lever is at the stop position, I still get spark to the plugs. Sorry for the noob questions, this and my HD25 are my first experience with outboard motors.
Totally stumped!
-KarlSeptember 14, 2015 at 3:01 am #23815Here’s a shot of the mag plate.
-KarlSeptember 14, 2015 at 6:21 am #23826I don’t think it is possible to install the plate wrong. Except maybe the carburetor throttle link (?). No, that one does not have the kill switch.
One thing that I see and don’t like is the way the points’ springs don’t lay flat against the tab. Probably not a problem, but is it another example of poor Sierra quality? Also, I don’t see the little brass clips on them
September 14, 2015 at 12:48 pm #23844Are the plug wires reversed?
September 14, 2015 at 7:46 pm #23869Looks like the points cam is damaged ?
September 14, 2015 at 9:01 pm #23873The points cam looks to be cracked.
Greg
September 18, 2015 at 3:58 am #24128I went back over the timing cam, and there was crud on it, but it isn’t cracked. I did convert the fuel line from metal to tygon, so it would be easier to take things apart. The inner diameter of the tygon is 3/16th, would a bigger fuel hose some increase the volume of gas that the carb was getting?
-Karl
September 23, 2015 at 3:59 pm #24454you could check that when the points are open that the correct piston is a top dead center.Slim chance that the cam is wrong and is firing when the piston is in the wrong position.
September 23, 2015 at 5:37 pm #24456quote burnt clutch:I went back over the timing cam, and there was crud on it, but it isn’t cracked. I did convert the fuel line from metal to tygon, so it would be easier to take things apart. The inner diameter of the tygon is 3/16th, would a bigger fuel hose some increase the volume of gas that the carb was getting?
-KarlNah!
September 23, 2015 at 7:57 pm #24462The float valve is what determines the fuel volume. Using a garden hose shouldn’t make any difference.
