Home › Forum › Ask A Member › TN-26 Lower Unit Seals – New Owner
  • #6303
    jlhtec
      Hello,
      I recently bought a locked-up TN-26. Honestly, I just thought it was cool and would be great yard art and conversation piece at my lake house.
      However, The tinkerer in me could not walk away without trying to get it running… I removed the lower unit and got the motor running with a good carb cleaning / reseating the float pin , and tuneup.
      The lower unit drive shaft was locked up, and required several cycles of CLR acid baths along with a torch to free it up. In the process, I broke the Clutch spring and am sure the seals are toast.
      Could someone please point me to the necessary seals to reseal the lower unit? So far I believe the 18-2032 is the prop shaft seal, but I am sure there are other seals needed.
      Thank You,
      Jeff
      #52659
        Jeff,
        I have a seal kit made up for the TNs. Shoot me a PM with your email address.
        #52811
        jlhtec
          Thanks Chris!!
