Home › Forum › Ask A Member › Timing tool
  • #267693
    james hobson
      Anyone know where one can can buy a timing tool and is it necessary. Also where can I buy parts for a 1956 15 Johnson, front control plate and hi low and choke knobs carb linkage from throttle to carb also need top half to air intake thanks
      #267694
        Richard’s Outboard Tools | (richardsoutboardtools.com)
        • This reply was modified 4 years ago by frankr.
        #267717
          the timing tool is excellent and I have used one several times….. yet  a common  bulb and battery on the points and  ground   will do the job  as well as a ohmmeter
          http://www.youtube.com/watch?v=ga1Cjymj6ms&feature=youtu.be
          • This reply was modified 4 years ago by JACQUES.
          #267738
          james hobson
            Thanks for the info I just ordered one.
            #267774
            fastjohn
              This video should be redone with it in focus at all times.
