Home › Forum › Ask A Member › Timing marks 1955 Bigtwin
Viewing 6 posts - 21 through 26 (of 26 total)
  • #56957
    JOSEPH BRINCAT
      Richard, I seminar or perhaps an tech article in the "Outboarder" covering the use of the Magneto Syncronizer would be of great interest to me and I’m guessing many others.
      #56967
      fisherman6
        quote Richard A. White:
        Flywheel must be removed, and Frank’s timing tool used to set points, actual gap is not as important as "when" the spark occurs.
        I can do a seminar at Constantine…If that would help
        Richard,
        If you do a seminar at Constantine, I hope it is while I’m there. I ordered one of them today. I may or may not have it figured out by then. I’ll only be there on Saturday. It seems like this will be a very useful tool.in getting the best run / idle quality possible.
        -Ben
        OldJohnnyRude on YouTube
        #56971
        RICHARD A. WHITE
          Well, I will see what I can do on an article in the Outboarder……I am not very eloquent, but I can give it a whirl
          Would still be able to do a Tech session at Constantine as well…
          classicomctools@gmail.com
          #56973
          fisherman6
            That would be excellent. I’ll look forward to both.
            -Ben
            #56989
            WAYNE
              quote Mumbles:
              There was a discussion here a year or two ago about using the aircraft synchronizers on outboard motors but I can’t remember where it ended up. Now I’m wondering if the ATOM ignition modules don’t use this same principle since they improve the idling and starting characteristics so good.[/color][/size]
              I remember that conversation. There was some good information in there, although things went off the rails a bit. I use the same atomizer/buzz box that Richard mentioned. I’ve used it for years and wouldn’t do it any other way. Its especially good for setting up the Mercury 4 cylinder magneto and stops.
              Here is the old thread on this subject…
              viewtopic.php?f=2&t=703
              Wayne
              Upper Canada Chapter
              uccaomci.com
              #57200
              hmai
                Thanks for the help guys. As i suspected, timing was slightly late. It now starts on the 1st pull
