Home › Forum › Ask A Member › Timing fixtures
  • #7303
    regnibe
      Hi,
      Can someone tell me what motors these timing fixtures are for?
      Approximate diameters are indicated.
      Some legible numbers are stamped on:
      1. .656
      2. .843 (304668)
      3. .843
      4. .906 (386636)
      5. .968 (304688)
      6. 1.093 (309173)
      Appreciate your help!
      J. Regnibe
      #59487
      RICHARD A. WHITE
        I have the tapered plug gages, but those being OEM tools they have no taper
        #1 is for the 3-4 hp, that is easy.
        Your #6 is either for the 28-40hp 1962 and up OR, it may be for the 1976 35 hp and 40 hp from 1974-1976 depending on where the "T" and "B" are stamped in relation to the key way
        I have taken over for Frank Robb who started making reproductions of these exact tools. He went the extra mile by making ALL of his with the correct tapered bore so they fit better on the crankshaft. I continue that tradition.
        The others are more difficult
        classicomctools@gmail.com
        #59490
        ed-sam
          My Special Tools Instruction sheet lists this
          pn 383603 3 & 4 hp engines
          pn 383602 all 5 thru 20 (except 1974 and later 9.9 an 15) & 1969 and later 25 hp
          pn 386636 all 9.9 & 15 1974 and later
          pn 383601 all 22 thru 40 thru 1961
          pn 378966 all 28, 33, & 40 hp 1962 thru 73
          pn 386635 all 40 hp 1974 and later
          print date 2/78
          now you know.
          Ed
          #59491
          RICHARD A. WHITE
            Thanks Ed, but I notice the numbers on his are the original numbers and your numbers are later.
            I gather that they superseded from his numbers to yours?
            I see he has
            308773
            304X88
            38063X…
            man that is going to be cornfusing…lol
            #59503
              Having problems with my Walagata account – other wise I would post the Test prop numbers as of 1962 . . . 🙄
