Home › Forum › Ask A Member › Timing a 1923 model A Johnson?
  • #298359
    TOM GOEPFRICH
      Does the chisel mark on the lower edge of flywheel indicate  when the points should open? Like maybe just as it is in alignment of edge of timer handle. With my points set at .020″ the mark on flywheel is about 5/8″ before timer handle.
      #298361
      GARY
        When the mark on the flywheel aligns with the one on the mag plate the points should just be opening and pistons approaching top of stroke.
        #298362
        TOM GOEPFRICH
          Yep, I just came in from the shop to say I removed mag plate and saw the timing mark.
