Home › Forum › Ask A Member › Tillotson MD float bowl drain seal?
  • #4892
    amuller
      The bowl drain resembles a long thin nail, spring loaded against some sort of seat. Appears to me there should be some sort of seal under the head of the nail. The parts blowup I have seems to show some sort of tapered seal but it’s not very clear. I presume this has been figured out already by people on this board…. Suggestions?
      #41394
      JOHN D.
        On my Scott Atwater motor I have eliminated this drain valve completely and used screws and fiber washers to plug the holes. Figured that was one less place for a fuel leak.
        #41395
          Ditto, me too.
          #41414
          amuller
            Just sealing it up is one answer. I’m thinking to try a piece of the yellow small-bore vinyl fuel hose. Carefully cut off square with a razor blade, it might seal in the conical seat. Also thought of the Tecumseh bowl drain gasket (27554) but these are made to seal on a flat surface.
            #41435
            amuller
              The valve stem ("nail") measures about 0.092 inch. The smallest size of vinyl tube at my local Ace hardware is marked 3/32 x 3/16 inches. It seemed to be a light push fit on the stem. So I installed a 1/8 inch piece with no attempt to bevel the end, this giving about 1/16 inch stem travel. Probably it will deform somewhat to fit the conical seat. Possibly it will deform too much and squish out of place.
