Home › Forum › Ask A Member › Tiller handle
  • #5069
    russ
      I have a Johnson RD-10 and I would like to remove the gear at the end of the tiller handle. It looks like there is a roll pin that is holding it on.Does any one know if that is what I have to remove to get the gear off. Thanks Russ…
      #42709
        Yes, that’s it.
        Drive the pin out and the gear will come off the shaft.
        #42711
        opposedtwin
          And that roll pin should be re-usable as long as you don’t destroy it during removal. I have had some trouble with the pin removal due to corrosion. Not sure if it was stainless/aluminum incompatibility or just old a stuck.
          Mumbles: how are those pins sized? Just by length and diameter? Easily shortened without destroying?
