Home › Forum › Ask A Member › Thrust, hp, and weight comparisons
- This topic has 53 replies, 13 voices, and was last updated 2 years, 10 months ago by
Charles Myers.
September 26, 2023 at 5:37 pm #281054
What a beautiful rig! That Evinrude looks great on the transom for sure.
September 26, 2023 at 8:57 pm #281062That is a beautiful machine!! Assk here if someone will help you. If I can boast the guys here are the best & will give you the best service. Love the navigation lights & horn. You have a real treasure. Please post your progress for all to read & enjoy.
September 26, 2023 at 11:43 pm #281070Absolutely outstanding boat/motor combo! Definitely keep the Evinrude!
"Every time you remove a broken or seized bolt an angel gets his wings."September 27, 2023 at 7:52 am #281072Phil, if worried about spewing oil in the water you can always look up some posts on here on diverting the purge valve residue over to a holding tank. You can remix the crankcase juices back in the fuel tank . The only oil and fuel to reach the lake will be from a small % of new fuel/oil bypassing on the cyl up stroke.
ok back to the beauty….rig…beauty is more important than speed at an older age 🙂
September 28, 2023 at 8:33 pm #281092you cant put a yamaha on that beautiful boat 🙂
mn
September 28, 2023 at 10:25 pm #281094Yes, The guys have figured a way to make an unburned oil can in the back to make it a cleaner running motor. Personally I would no use it again though. Looking forward to more progress pictures!!
Charles
Read post on Oil & envirement. Great educational data!
October 1, 2023 at 2:36 pm #281169I would not replace the motor unless you have a need to operate where 2 stroke engines are no longer tolerated.
What’s the problem with synchronization of spark and throttle? This is generally a pretty simple matter. Some big twins have a more complicated linkage that could take a bit of effort to figure out, but I doubt yours has that additional complexity. People here will know.
October 2, 2023 at 9:39 am #281200to service your oldy you can try downloading the Johnson bible and print it locally double sided. not Evinrude but they are cousins 🙂 (same father)
https://watercraftmanuals.com/outboard/johnson/manuals/johnson-302231.htm
October 5, 2023 at 8:38 pm #281360Thank you, amuller. The synchronization process that I have tried is in the attachment. Does it seem correct to you?
What baffels me the most is the fact that loosening the two bolts for the throttle cam does not let it move at all.
October 6, 2023 at 2:35 pm #281372Thank you, amuller. The synchronization process that I have tried is in the attachment. Does it seem correct to you?
Kind of hard to follow with no pictures. I’m wondering if this engine uses the “economizer linkage”? If so, I was guessing that it might not be set right causing a lack of power due to only partial opening of the carburetor butterfly at WOT.
Charles: feel free to post a picture of the left side of the powerhead with the engine cover off, then we can see if it has this linkage… D
