Home › Forum › Ask A Member › Throttle lever pin?
- This topic has 9 replies, 5 voices, and was last updated 3 years, 11 months ago by
jimk.
November 25, 2022 at 1:01 pm #269369
Has anyone here made one out of metal? Part number 0329197. Expensive little part for what it is and I belive it could be made out of a piece of aluminium ground down. Any reason it shouldn’t work? I have replaced a few on some of my old Johnson and Evinrudes and have a Evinrude that needs one now and figure I could just make it.
November 25, 2022 at 4:37 pm #269373The tangs on these pins tend to break when the mag plate is tight and the throttle is twisted hard. So, I’ve made them out of 3/8″ round Acetal plastic (Delrin). Without a mill, I set them up in the lathe and used a cutter to get the tangs right. Since they slide up and down in the aluminum throttle gear, making them out of aluminum might be a bit harsh as a plastic pin should wear out before the slots on the aluminum gear do. Just my two cents.
November 25, 2022 at 7:04 pm #269375I had one in a old parts motor in good shape but I think I will use it as a guide and go ahead and make up a few. I belive my local Menards sells the delrin rod so next time there I will have to check. Thanks for the idea!
November 26, 2022 at 10:28 am #269377At one time they were made of metal. I run across a metal one every now and then. Maybe brass? Maybe an after-market product back in the day?
This reply was modified 3 years, 11 months ago by
CHUCK.
November 26, 2022 at 10:39 am #269379I made one from aluminum with no problems. kept well lubed.
November 26, 2022 at 1:02 pm #269380I have a 1955 Johnson 5.5 and it is all metal. One piece throttle arm so thats what made me think of useing aluminum.
November 30, 2022 at 7:58 pm #269553I’ve got a (small) bucket of those things. I can mail you a few if you want to pay postage..
December 1, 2022 at 10:02 am #269581retiredoz-Thanks for the offer on that but for now I will see how making up a few goes. I have good ones now in all my motors but would like to have a spare or two. I picked up a 3/8 inch aluminum rod and see how that goes. They should be a bit stronger and as long as I keep them well greased I don’t think there will be much wear. Seems every old motor I pick up at least one of the ears is broke.
December 1, 2022 at 1:34 pm #269592just a though how about making a pin to replace the broken tabs? Roll pin?
December 1, 2022 at 1:56 pm #269593Not sure about a roll pin but that would probably work. Just drill threw the plastic thats left in there. I just went out to the garage and made 2 out of the aluminum rod and only took 20 minutes, I will have to see how they hold up if I have another break or pick up another motor with a broken one.
