Home › Forum › Ask A Member › Thread Size for OMC Waterpump Screw–need Helicoil
  • #5014
    raglover
      I need to put a helicoil in one of my OMC lower unit water pumps. 1957 35 hp model. It is the standard flat head screw used in all of them.
      I forgot to bring it with me today to measure the size and thread so I could pick up the parts at Fastenal. Does anyone know it by heart?
      I would guess it is a 10-32?
      Thanks,
      Allen
      #42348
      RICHARD A. WHITE
        Maybe 10-24, but I don’t have one in front of em either
        classicomctools@gmail.com
        #42349
        fisherman6
          I’m pretty sure it’s a #10 screw but I don’t remember it being a fine thread. Hopefully someone knows for sure but I’m thinking it’s #10-24 UNC. I certainly could be wrong. Dan Anderson would likely know from memory.
          -Ben
          OldJohnnyRude on YouTube
          #42350
          wedgie
            3/16 (#10) – 24 and 1.165 long including head
            #42351
            Leon
              When you put that heli-coil in, make sure the end of it is flush, or just below that flat surface, because your waterpump will no work correctly if the wear plate is not sealed to that surface properly.
              #42352
              Leon
                Yea, that would be a 10-24 thread, if it measures 3/16" nominal size is technically .190
                #42354
                wedgie
                  Yeah, just thinkin’ like an amateur carpenter here . 😕 😆
                  #42356
                  Leon
                    It’s all good. You are correct though. Most #10 screw sizes measure out in that size. Some even go as low as .180
                    #42359
                    raglover
                      Thanks Everyone!
