Home › Forum › Ask A Member › Thread on the linkage screw 304204…
  • #279749
    cron78
      …on ’58 10hp Johnson?  I think I need to tap it to clean it to get the darn thing to take.
      #279753
        Would you be referring to the plastic idle speed screw on the throttle gear?  1/4-20
        #279761
        cron78
          No, sorry for not being more descriptive.  It’s the two screws/bolts in the shift rod connector holding the upper and lower shift linkage rods together in the lower unit behind the port that allows access to unscrew one to remove the gear case.
          #279771
          Dale
            Oh that puppy is a 1/4 x 28.  It is easy to cross tread and it needs to be tight.  Not one of OMCs best move in MHO.
            dale
