Home › Forum › Ask A Member › Thor opposed twin tiller handle
  • #302546
    NATHAN KILLIAN
      US Junior Member
      In addition to the pal I posted about, I also acquired a Thor opposed twin today.  The steering handle was not present and this is a project I will not truly attempt until summer, but how should I go about finding/making a new tiller handle?  It seems to be the same one used on some Thor singles.
      #302565
      PM T2
        Its a piece of tubing. 7/8|” diameter, I think. Cut to length, drill a hole for the pivot bolt, grind the bottom off so that the tube has an open side, then squash it in a vise to close it down to where its open enough to fit over the mounting stub.
        Thor-handle-1
        Thor-handle-2
        Thor-handle-3
        Put a grip on it if desired. This took me about 10 minutes to make from start to finish. Easy peasy.
        PM T2
