Home › Forum › Ask A Member › Test Runs
  • #1205
      It was such a beautiful day, I decided to try out three different outboards I went through this
      winter, Waterwitch 571-10, 1962 Eska 5hp, Mercury Mark 6.
      Have you ever completely gone through an outboard and
      have everything test out perfect? No me…… not ever close, lol.
      Eska fired up after about 10 pulls, sounded pretty good.
      Died a few times, so got a screwdriver so I could adjust the carb.
      Went to restart, and rewind rope pulled all the way out and wont
      retract.:-(
      Tried the Waterwitch next. Started up in a few pulls, ran so so,
      trying to fine tune. Started out pumping water pretty good,
      but slowly quit pumping water. 🙁
      Threw the Mark 6 in the barrel next. Hooked up the
      gas tank, squeezed primer, and found a gas leak right
      away. Had to pull the choke assembly and baffle plate
      of to get at it of course. Fixed Leak, put it back in the
      barrel. Fired up right away, sounded good, but needed
      some tuning. Checked for water pump output and
      found no water squirting out anywhere. Seemed
      pretty warm after a couple of minutes, and then
      it died. 🙁
      Does the Mark 6 have a tale-tale to know if the pump
      is working? Brand spanking new impeller btw.
      Am staying out of the garage tomorrow……. too depressing, lol
      ddoyle
        Depressed ? I got a cure. Just go to your local outboard dealer and price new OBs in the same HP range. That trip will quickly make leaks, impellers and recoil springs seem insignifgant. My local Evinrude dealer has a "sale" on 3 hp kickers. $1875.00 cdn 😮 The sign is large and they are re proud of offering deal LOL. Shop rates for repairs are posted a few feet away $105.00 cdn/hour. First 30 mins is a cleaning fee.
        #13981
        benchrascal
          Test runs are more a test of patience than anything else .Murphy’s law is the rule and expecting the unexpected is the norm .One day I’ll toss a motor in the bucket and it will purr ,first pull ,today is not that day nor is tomorrow but it will happen one day .
          #14002
          Doug Wilson
            we have all had days like that, I had one that started great at home but at the lake pulled 10 times or more every time I tried to start it. the merc 110 almost became an anchor minus the rope that day, finally took a look at it upper crank shaft seal is leaking real bad.
            Doug
            turned off?
