Home › Forum › Ask A Member › TD/HS carb leather gaskets
  • #5805
    b-morrison
      who makes these and is there an address/number/email address? Brian in Winnipeg,Manitoba
      #48302
      david-bartlett
        I copied this info from the Poche family website.
        http://pochefamily.org/outboard/
        Hope it helps. Not sure if price is still current.
        David
        FOR SALE JOHNSON LEATHER PRIMER PUMP SEALS for TD, TN, etc.
        If your old Johnson drips fuel from the carburetor when you push the primer, you need these seals and instructions. If you have tried rubber O-rings or other materials, you already know they won’t work. Gaskets and cork floats are easy to make, but these leather seals are very difficult to reproduce so that they work properly. Don’t worry. These are new seals made from pump leather, as original, and fit all old 5 hp, 4.2 hp, and 2.5 hp Johnsons including Models TD,TN,AT,LT,DT,HD,HA,HS, etc. Includes detailed diagrams and instructions for proper installation that are not found in the Factory Service Manuals. The instructions alone are indispensable. Not necessary to remove carburetor.
        Send $8.00 per set (cash only, no checks) and SASE (self addressed stamped envelope) to: Lloyd Lautner, 9289 North Long Lake Road, Traverse City, Michigan 49685
        Stop leaking and keep yourself and the "tree huggers" happy!
        Lloyd Lautner AOMCI
        #48330
        aquasonic
          I am not sure if LLoyd is still making these leather seals, but I hope he is. If you can get them from LLoyd, please let us know. If not, there are several other sources to check.
          Improvise-Adapt-Overcome
          #48444
          b-morrison
            Spoke with Lloyd tonoght and he is in business as we speak and is making up a new batch. Price,and all other info remains the same…..Brian
            #48446
              Brian
              How is Lloyd doing?
              Any chance he’ll be back on the boards?
              Steve A W
              #48453
              aquasonic
                quote B.Morrison:
                Thanks for letting us know. I have not seen any postings from LLoyd for quite some time, but I’m happy to hear that he is still making leather seals.
                #48461
                b-morrison
                  give him a call. He’s in the directory. ….Brian
