Home › Forum › Ask A Member › Tandem/Twin motor setup
  • #312472
    Brad Richmond
      Can anyone point me to information regarding the setup and running of two outboard motors on my boat.
      steering setup?
      throttle and shifter setup?
      counter rotating propeller setup?
      working to setup and run a pair of RJE-18’s on the back of my Crestliner Viking run aboutIMG_3791-2
      #312568
      Dale
        Hi Brad, just what do you want to know?  Those 30 horse Johnsons will push your boat pretty good.  You will need a good size boat.  I run my tens in tandem, and it sure is fun!  I know nothing about counter rotating propellers.  I stacked two control boxes together and that works.  I use a cable system for steering.  That does take some engineering.  I don’t know how handy you are and how much time you want to spend setting it up.  It is a good off season project for sure.   I have lots of pictures, if you are a member PM me and I will send some to you.
        dale
        Sweet Runners!
        Dual Controls
        #312599
          Those twin 30s and twin 10s both look great!
          1982 Evinrude 25hp
          #313069
          MIKE SIMS
            Here is the 1957 Johnson Parts catalog for Twin Controls if it  helps.
            57johnsoncontrols
            57johnsoncontrols2
            #318291
            Brad Richmond
              Update:  I was going to marry two shipmasters together, but I just scored a dual unit ship master on eBay.
              aldo scored the tech sheets showing the in between link.  Looked simple, appears to be a 1/4” rod with eyes loops bent at each end and a turn buckle for adjustment.  Then connect it to the regular steering brackets on each motor.
              now I just need to finish cleaning, painting and reassembling the motors that will be wearing the already restored cowls.  Might just load a couple of my working RJE-18 motors that are working but not in cosmetic restoration yet so I can get everything fitted up and able to demonstrate the set up at one of our wet meets.
              i am excited to get this finished!
              thanks for all the help!
              #318292
              Brad Richmond
                Thanks Mike Sims your tech sheets you posted also show the center rod that ties both motors together for steering.
