Home › Forum › Ask A Member › Sure Hope those are strong bolts
  • #981
    CHUCK
        Definately not the best way to pod a boat! The motor has already had a rough life as the port side transom bracket has been welded before.
        #12460
        bobprock4200
          Someone’s attempt to convert an I/O to outboard?
          #12462
          r-amp-d
            Interesting! I don’t believe that was installed per manufacturers spec. 😆
            #12467
              When Ya just gotta go fishin ❗ 😈
              #12472
              DAN ANDERSON
                I sure hope that rig doesnt go very fast (looks like it won’t) because if he hits a submerged object, that motor is coming in the boat with him! Never a good idea to restrain the travel of the engine upward so the shocks can control the inertia. At least it doesn’t have trim on the motor.
                Dan in TN
                #12479
                Ron Devries
                  Certainly not someone with any engineering logic. I’m good with the re purposing the boat to have an outboard but maybe just put a 9.9 on it to push it where you want to go/test out the theory. Wider wood blocks and 4 bolts comes to mind as well.
                  #12495
                    As Charlie Brown would say, "Good Grief".
