Home › Forum › Ask A Member › Stuff that drives you crazy.
  • #275121
      One of the things I enjoy is figuring out what’s
      wrong with something.
      This hobby provides a lot of fun in that regard.
      Many like minded individuals frequent this board.
      This is for them.
      This was something someone did with good
      intentions but ended up having a negative
      result. Something I have been guilty of more
      times that I am wiling to admit.
      This is not a quiz or looking for a response.
      I have figured it out.
      I’ll reveal what I found in a couple days.
      Just something to ponder for those who enjoy
      trying to solve a mystery.
      Click on the video link.
      https://youtu.be/a-wEyHdfWX8
      #275122
        glad carbon monoxide didn’t calm you down !!
        #275127
          I’m not sure but maybe  sticking float when bowl was empty?
          #275128
            Plugged up vent to the carb bowl? Somehow related to the heating and cooling?
            #275130
            Tom
              Is the tank vent plugged?  Or have you switched out the vented valve?
              #275186
                When I open the fuel shut off and the gas goes into the “warm”
                carburetor, it vaporizes some. Someone added this little brass
                bushing for a better fit of the float needle. It’s not so tight that
                the float pin sticks but when pressure is created in the float
                bowl it cant escape fast enough forcing fuel out the main jet
                – as billw has described.
                Its done so well that it looks factory. I was considering drilling
                a hole in cover when I noticed none of the other carb’s I was
                looking at, for some indication of what the problem could be,
                has this bushing in the cover.
                #275188
                opposedtwin
                  Can you simply widen the opening in that added brass bushing so there’s a bit more slop for the needle to move around and allow air to flow by it more readily?
                  Is the brass bushing swelling from heat too quickly and reducing that space around the needle?
                  #275189
                    Before posting the video I increased the size
                    of the hole in the bushing to be sure I understood
                    the problem. Opening the hole just .004 more
                    seemed to have solved the problem.
                    #275191
                    Dale
                      There should be a vent hole in that bowl cover?
                      dale
                      #275202
                        It seems that the hole for the float needle is also the
                        bowl vent.
                        I have several of these carburetors and there
                        is no indication that any of them had a separate
                        vent hole.
                        Checking some of the other carb. bowl covers I
                        have, its understandable why someone would
                        think installing a bushing would be an improvement.
                        Actually now that I have made the hole large
                        enough so the bowl can vent it is an improvement.
                        Necessary? Probably not.
