Home › Forum › Ask A Member › stronger spark, why?
- This topic has 8 replies, 6 voices, and was last updated 9 years, 5 months ago by
Tubs.
June 6, 2017 at 3:33 am #7259
I’ve noticed on some of my twins that one side has a stronger spark, able to jump farther. Could this be because of the points gap? Such as a larger gap having a weaker spark because points stay closed for shorter time? smaller gap producing a stronger spark? Any thoughts appreciated.
June 6, 2017 at 6:41 am #59107That is a possibility. The points are supposed to open at a certain time as the magnets pass by the coil. It is the time that they open that counts, not the gap. But the gap is related to the time, so it is one method of setting them. The accurate way is with a timing fixture. I’ve made a ton of them, but have turned it all over to club member Richard White. http://www.richardsoutboardtools.com
June 6, 2017 at 6:45 am #59108I had a similar issue and it turned out to be one condenser that was weaker than the other. You can test them with a multi-meter.
“The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy.” ― Martin Luther King Jr.
June 6, 2017 at 10:50 am #59113From swapping coils I believe that some coils just work better than others.
June 6, 2017 at 11:38 am #59117Check resistance of condensors?
June 7, 2017 at 4:00 am #59178quote OLCAH:From swapping coils I believe that some coils just work better than others.I think this is a good point, especially if you are using two different vintages or manufacturers of coils. Coil design has certainly changed over the years, and who know just how aftermarket coils were engineered/designed.
So, comparing spark when mixing vintages of OMC coils, or mixing manufacturers might be like comparing apples to oranges…
Will both cylinders jump a 1/4" gap? If so, I wouldn’t overthink it based on capability beyond 1/4". Is there a particular project that has prompted your question?June 7, 2017 at 1:13 pm #59190I am working on 57 West Bend/Elgin 7.5. I fitted it with omc coils. I swapped the condensors and the weak spark went away. I must of had a poor connection. I have great spark now.
June 7, 2017 at 2:05 pm #59193Cool, am glad it is ressolved
June 7, 2017 at 2:08 pm #59194 -
