Home › Forum › Ask A Member › Stripper bolts size and TPI for 81 Evinrude 15
- This topic has 8 replies, 7 voices, and was last updated 4 years, 5 months ago by
Don.
June 5, 2022 at 12:24 pm #260993
I am having a time finding the correct stripper bolts to remove my flywheel on the 1981 Evinrude 15. I need to lubricate the stator plate rotation. Advice appreciated. My first post here. Hope to learn and share.
June 6, 2022 at 9:21 am #261043.
June 6, 2022 at 10:40 am #261046I have seen most if not all those videos. The process is familiar to me and I have gear puller and harmonic puller, but the latter uses the three threaded holes adjacent to the center nut for purchase points. The OMC tool for this is a harmonic tool also. I just don’t have these 3 bolts to fit the thread size and pattern of these holes(Stripper bolts). I hesitate to use a gear puller on the edges of the flywheel(warpage). I was hoping someone knew the exact size and pattern of these bolts.
T
June 6, 2022 at 10:40 am #261047“Stripper Bolts”, otherwise known by various names such as shoulder screws. Grade 8 strength, they are what comes with the OMC flywheel puller. The motor in question most likely has 1/4-20 threads.
June 6, 2022 at 9:07 pm #261079Great! The shoulder bolts I’ve seen were difficult to determine whether their listed size applied to the thread diameter(1/4”) or the shoulder diameter. I will do some more looking.
Thanks for your response.June 6, 2022 at 10:40 pm #261083Under no circumstances apply a gear puller to the flywheel rim… NEVER.
As for the bolts, I have used regular grade 8 bolts , 1/4 – 20 I believe for your motor. Put strong tension on the puller, then a good hard blow to the puller screw with a heavy hammer. Be sure to still have the flywheel nut installed, just backed off a few turns., unless you are good at catching a flying flywheel.
June 7, 2022 at 5:55 am #261095Take your pick, here:
https://www.mcmaster.com/shoulder-bolts/alloy-steel-shoulder-screws-9/thread-size~1-4-20/
June 7, 2022 at 11:27 am #261109There us a how to video worth a look and learn…pot metal flywheel on Lightwin was not responding to usual techniques so I went online to see how the pros do it, Pretty simple. install flywheel puller, tighten up AND then whack top of rim of flywheel alternating sides…IMMEDIATE results. This seems to be a dealership mechanic Time is Money technique to get the job done asap.
Louis
June 7, 2022 at 11:39 am #261110Yes, the OMC puller is really a must. Using alternate pullers, with bolts that aren’t tough enough, usually leads to broken bolts inside the flywheel, and damaged igntion components under the flywheel. It’s your engine, so it is up to you. The part number for the new plastic mag plate bushing is: 322435
