Home › Forum › Ask A Member › Still No Spark
- This topic has 29 replies, 6 voices, and was last updated 3 years, 2 months ago by
Mumbles.
August 18, 2023 at 9:48 pm #279407
deleted
August 18, 2023 at 10:58 pm #279409Deleted
August 19, 2023 at 1:28 pm #279417deleted
August 19, 2023 at 8:36 pm #279434deleted
August 19, 2023 at 8:57 pm #279435deleted, as well
August 20, 2023 at 7:10 am #279439Seems to me that if you put a piece of paper or thin card board between the points and turn the key on, you should see nine to 11 volts on the points insulated side. Is this true?
The coil pair next to the points is likely for charging the battery and has nothing to do with the ignition. The ignition coils are on the head. You probably know this but just sayin’, to be clear.
August 20, 2023 at 10:47 am #279450Deleted
August 20, 2023 at 12:43 pm #279457deleted
August 20, 2023 at 1:50 pm #279459Please tell me what “Spark plug tube is” The ignation circuit seems to me to be no different than an automotive circuit, very basic with power, small wire to points & capacitor & one to the spark plug lead, from secondary winding. The others are safety control switches, choke & charging system. Pick one system at a time & research & repair before doing the next system. The rectificter seems very common to Mercury outboards, Honda Motorcycles & every else a bridge is used with 4 terminals ( don’t forget the bonding, grounding terminal. Both outputs generate 1/2 wave direct current, t’s very much the same as any outboard except the primary winding power comes from a battery supply & not using magnitism.
I assume the pink, orange brown terminals are part of the tachometer as sensing terminals as the othher two wires are the power supply + & = maybe a lamp for night use with a common bond or ground by mechinacial means. Not hard to understand taking one system at a time remembering they are totaly separt systems like Frank stated. just a different shape you may not be used to.Don’t be confused with “common” terminals linking the three systems to the power supply (battery) also. Again Frank has it correct, get the coils working fires. I had an outboard with a flakey bond th the ehgine block & one coil sent hi voltage to the other coil turning the points gold hot. You might trying bonding the magneto plate to the block as it turns when throttle is advanced & retarded. Dirty grease is a dielectric or insulator.
Good luck
August 20, 2023 at 3:16 pm #279464deleted
