Home › Forum › Ask A Member › Stator 5.5hp ’55 johnson cd10
  • #210985
      How is the stator plate removed?
      #210986
        screws…. remove all the ones on the plate ( 2 long ones on the coils 2 short ones see #1 #2 ) disconnect mechanical parts
        pull up
        #210995
          Thank you. had already done that including removing point rotor, and coils. Wont budge maybe not enough strength, but concerned about using pry bar under it. Any additional thoughts? Thanks again for your help.
          #210996
            #210997
              Does the plate swivel back and for normally while in place?
              If so, it’s not binding on the power head. Perhaps
              you took out a couple of the wrong screws?
                Those four screws are all that hold it down. I should lift off with ease by only fingertip pull, no forcing required. If it doesn’t swivel back and forth, perhaps it is corroded in place. How does the rest of it look? Lots of corrosion?
                #211014
                  I see a circular clip at the bottom of the plate dose this have to be removed? all the screws have been removed. 1 long one and 2 shorter for each coil. Tried a 3 legged puller with mild pressure and tapped several times.Nada.
                  #211018
                    If all you have removed are the 3 screws on each coil, the plate won’t come off. There are 2 others to remove – see the picture crosbyman included in his post above or see the enclosed pic from my ’54 CD-11, essentially the same as your motor. There is no clip below the plate – there is a support ring which won’t come off until you remove the magneto plate. And don’t use a puller on that plate!!
                    1982 Evinrude 25hp
                    • This reply was modified 6 years, 3 months ago by Bob Wight.
                    #211024
                      suggest you read the following
                      http://www.leeroysramblings.com/johnson_magneto.htm
                      if you are going to pull the plate may as well redo coils (inspect closely for cracks and burn marks) , plug wires (metallic 7mm) etc…
                      lots of utubes on omc magnetos
                      #211070
                        Thank you. Went back and looked found 1 screw hidden by points on each side, removed same. All good lifted right off. Thanks again.
