Home › Forum › Ask A Member › Stabilizing a peeling original label
- This topic has 8 replies, 4 voices, and was last updated 3 years, 10 months ago by
JOSEPH BRINCAT.
January 8, 2023 at 8:37 am #270848
I picked up this beaut for $160 at auction. Is in real good shape and even appears to have been running in the not too distant past. Water jacket does seem to be leaking into a cylinder though..
It does have the original labels on it. However, almost as soon as I got it the environmental changes have made the label start to peel. Any recommendations on reattaching the fraying edges and stabilizing the whole thing?
January 9, 2023 at 8:19 am #270950When they were still in business,Reprotint outboard paints sold a spray lacquer just for that purpose.I bought a can and used it on several decals like the ones you described and it worked great.I think any clear matte lacquer spray would work.Mask around the decal and spray a light mist coat first then follow up.Do a test first of course.
January 9, 2023 at 11:19 am #270959
Your decal is a waterslide replacement for the “Transfer” that
was used originally. Waterslide decals have gone out of favor.
A vinyl replacement may be available.
TubsA "Boathouse Repair" is one thats done without having tools or the skills to do it properly.
January 9, 2023 at 7:33 pm #270965Oh, so its not even original? That’s good to know, I was fretting keeping it together.
January 10, 2023 at 12:18 pm #270988
The original transfers are slightly thicker and were applied
with a stronger adhesive. This is a example of an original transfer.
They don’t flake off like a waterslide decal. There was some error
in the preparation of the surface or in the application of your decal
that’s causing it to fail.
January 10, 2023 at 3:29 pm #270992Ok guys, at great risk of crucifixion,…I think that the OP’s decals are originals and that all the old time decals were waterslide decals. Some may have been thicker than others but all water slide back in the day. As for preservation of the old decals, I would strongly caution about using lacquer based paint. The solvents in lacquer will attack the decal, instead use a clear enamel which is available in spray cans. Both Rustolium and Dupli-color make clear enamels, Duplicolor even makes a clear ceramic engine enamel that is very good.
As for Reprotint, to the best of my knowledge they only delt in enamels , no lacquer paints…AND their paint is still available under new management as http://www.vintageoutboardpaint.com
January 10, 2023 at 6:21 pm #270998Here’s my old can.Definitely lacquer and definitely for water slide decals.
This reply was modified 3 years, 10 months ago by
GARY.
January 10, 2023 at 7:54 pm #271006
With the best of intentions,waterslide decals appeared
sometime after WW-II. They replaced the transfers that
were applied to many early outboard motors. These are
the instructions for applying a transfer to a gas tank from
a 1930’s Johnson repair manual.
January 11, 2023 at 12:28 am #271017Thanks Tubs, much appreciate the info, I learned something new.
