Home › Forum › Ask A Member › 1938 opposed twin sea king coil seems inop
  • #302619
    Gregory Geurts
      Any compatible coil assemblies from same era but maybe different manufacturer ?  Newer options?
      Thanks in advance
      JGG13
      #302621
        How have you determined that the coil is bad. Have you cleaned the point assembly and checked for spark.  A picture of the coil in the magneto will help with possible options.
        #302647
        Gregory Geurts
          Hey Tubs, thanks for responding.  The primary circuit seems good, the secondaries bounce between 5 and the mid teens but I only have a digital tester.  Looks like someone replaced the condenser at some point so I need to test that yet.  Cleaned and set the points and there is definitely no spark to the plugs.
          JGG13
          #302648
          Gregory Geurts
            Tried uploading image and tried responding multiple time from different devices.  Web site keeps blocking me with errors.  Frustrating
            JGG13
            #302649
            RICHARD A. WHITE
              What errors?
              2 mb maximum size on your photos..
              It should just drag and drop into the box, then your photo will “transfer” to the box.
              Then you should see a thumbnail sized photo. If memory serves you should also see an option to include said photo into the body of your message.
              classicomctools@gmail.com
              #302650
                I got a 500 error yesterday trying to post.
                Usually, I get some other snag where only
                some of the photos will post, or are the
                wrong photos all together.
                  #302695
                  Gregory Geurts
                    Ok, thanks for all the suggestions. I misread the file size so this was likely my issue. The old 1D10T error.
                    20251221_142414
                    JGG13
                    #302705
                      try to post them in Powerpoint and  just shrink them
                      #302721
                      David Bartlett
                        <!–more–>This happens to me all the time!  Very frustrating.
                        David Bartlett
