Home › Forum › Ask A Member › Spring inside poppet valve
- This topic has 6 replies, 6 voices, and was last updated 2 weeks, 5 days ago by
ROBERT LAFAYETTE.
October 16, 2026 at 8:28 am #330136
Is this “spring” (looks bent or homemade) necessary and original?
Not sure how these poppet valves work. As I roll over the flywheel, it does make the burping sound but i think it is flooding out the motor.I got it to run for about 8 seconds but the spark is white/weak and I’m going to address that.
Thanks for any help!Scott
October 16, 2026 at 9:20 am #330140That looks like a needle to me, not a poppet valve.
That spring looks to be specific for exerting pressure to keep the mixture screw from moving.http://www.richardsoutboardtools.com
classicomctools@gmail.comOctober 16, 2026 at 10:29 am #330141
Here are the basics of how a how a poppet valve fuel mixer works. When the piston goes up, a vacuum is created in the crankcase. Air comes in under the poppet valve lifting it. Fuel is pulled up from the little hole under the poppet valve. It mixes with the air as it passes over the hole and goes into the crankcase. Pressure is created when the piston starts down closing the valve and pushing fuel into the cylinder for combustion. The amount of fuel that comes out of the hole is controlled by the mixture screw you’re holding in your picture. The purpose of the spring in your picture is as stated by Richard. It is necessary for the fuel mixer you have. That’s a poor substitute for the original.
October 16, 2026 at 3:06 pm #330148What Richard said. You will (should) find the poppet valve and its spring under the mixer cover… that top held on with two screws
October 16, 2026 at 4:17 pm #330150What Richard said. You will (should) find the poppet valve and its spring under the mixer cover… that top held on with two screws
Yes, they are both there.
October 17, 2026 at 9:39 am #330171I believe the spring you’re about is a tension spring to hold carb adjust in place. It is needed.
October 17, 2026 at 8:41 pm #330199 -
