Home › Forum › Ask A Member › Spot what’s wrong
  • #299850
    Dale
      Interesting, is the battery under the hood?  What  do you need water cooling for?   Do you want to sell those 15hp medallions?
      dale
      #299857
      Fastwin18
        fastwin18, that is a remarkable creation. Great work. Did you happen to use West System epoxy? If so, you should submit your project to their magazine ” Epoxyworks” … If you didn’t use their stuff, still worthwhile getting the West System magazine , its free and has lots of good “how too” info about epoxy and its uses. They would love your story…
        check out “epoxyworks magazine”
        Thanks for the tip Joe. I did not use West system but I’ll give their magazine a closer look
        #299858
        Fastwin18
          The battery is too big to fit under the hood. At the moment there’s only a new frame to keep the cowling face plate on, the engine speed controller (the black box) and the water pump. The speed controller can get quite hot when running at high power (above 3000 Watt) and needs cooling. I’m going for a test on the water today. If everything works as expected I will clean up the cables under the hood.
          I think I’ll hang on to the medallions for now 🙂
          IMG_20250913_080605
          #299862
          Mallett
            Looks great, neat job! Must turn a lot of heads when you on the water.
            #299876
              With all that wood on there you might have trouble keeping your prop in the water.
              #299885
                Fantastic piece of work!!
                1982 Evinrude 25hp
                #299891
                wek
                  There is a place in Saugatuck Michigan, Retro Boat Rentals,  that has a fleet of vintage boats with old outboards that have been converted to electric power that they rent out.
                  https://retroboatrentals.com/
