Home › Forum › Ask A Member › SpeediTwin flywheel question.
  • #3189
    david-bartlett
      I started working on my $25 Speeditwin, 1948 model 6039. The flywheel on this one will likely need replacement. The key broke at some point and things got a bit loose by the looks of the hub and the crankshaft taper. I believe I can use the crank as is, but the flywheel is iffy at best.
      Does anyone know what motors shared the same flywheel? I haven’t pulled the flywheel off my 1948 SpeediFour yet to see if they are the same. Externally they are identical, but underneath may be different. I will find out, but thought I would ask in case anyone knows. How about the BigFour? Just looking for options when it comes to finding a donor.
      The flywheel had a toothed lockwasher under the nut, which I do not think was supposed to be there. I have not seen one on other period motors. Again, can anyone say yes or no?
      The internals look pretty good. A little scorching, but no visible scoring of pistons/rings. It turns over freely now that I have got oil into all the moving parts. It was a bit stiff prior to that after sitting for who knows how long.
      I am hopeful that this will be a runner once I get the flywheel issue sorted out.
      #28705
        If you get stuck I have a spare, but shipping across the border might not be worth it for you! Those flywheels are heavy.
        #28706
        david-bartlett
          Chris,
          Thanks for that offer. I think I am going to try my SpeediFour flywheel on for a test fit first, just to check the fit with the crankshaft. If it fits OK, then I will start looking for a replacement. I think the original is too messed up for some J-B Weld and a new key.
          #28707
          Casey Lynn
            Try the Webvertise?
            #28795
            david-bartlett
              So today I removed the flywheel on my SpeediFour and verified that it is NOT the same as the SpeediTwin on the underside. Oh well, it was worth a try anyway. I learned something at least.
              A member from New Jersey has offered me one, so now just have to figure out how to get it from there to here.
