Home › Forum › Ask A Member › Spark Plug Wires – 49 Sea King
  • #280124
    John Gragg
      What would the group say about replacing spark plug wires? Before you all pelt me with ‘if it ain’t broke…’ advice, I’m 99% sure I have a bad coil. Solder joint wiggles a little when I apply pressure with my meter probe and readings go anywhere from 13 million down to 3K. Jumps all over the place. So I’m going to do exploratory surgery and remove the solder joint. Whatever the outcome, I then need to resolder that plug wire so I am thinking it’s the right time to replace these wires?
      Motor is not yet running, has compression but chasing a spark issue.  No idea about the carb, had it off and the reeds looked new. Silver, shiny, looked great. Tank and cowls are there, but tank has a ton of dings and dents. A full resto is probably not in the cards for this one. ( As much as I’d like to).
      Advice? Thx!
      John Gragg
      RIverside, CA
      Just starting in the hobby, please be patient.
      48 Sea King 5hp GG9014A. Sold
      49 Sea King 5hp GG9014A
      48 Johnson TD20. Sold
      49 Johnson TD20. Sold
      54 Johnson QD15. Sold
      55 Johnson CD12. Sold
      57 Johnson RJE-19M
      57 Johnson RDE-19
      #280128
      CHUCK
        Use 7mm Copper core wire;  NOT the newer type automotive stuff.
        #280131
        John Gragg
          I follow a guy on YouTube.  Brandon’s Garage. Trying to learn this outboard stuff. I was hoping that was the correct answer, because that’s exactly what he said!
          Thank You again!
          John Gragg
          RIverside, CA
          57 Johnson RJE-19M
          57 Johnson RDE-19
          #280149
          bob-d
            John, here is what I use, it’s on EBay.
            Bob D
            IMG_3193
            #280152
            John Gragg
              Perfect, thank you. I’ve been looking but could not find it by the foot.
              I appreciate the help!
              Best Regards
              John Gragg
              RIverside, CA
              57 Johnson RJE-19M
              57 Johnson RDE-19
              #280198
              aquasonic
                That’s some pricey sparkplug wire! There are other vendors with the wire priced at a little over a dollar/Ft. Of course, a 100′ roll can get you a price less than a dollar/Ft.
                I’m not cheap, I’m frugal!
                Improvise-Adapt-Overcome
                #280240
                  I believe the Packard 440 wire is correct for some auto restorations. That
                  may explain the price. Search eBay for ” 7mm copper core spark plug wire
                  by the foot” for some lower priced options.”
                  #280243
                  CHUCK
                    You might as well get a 100 foot roll of it and get it over with. Here’s the brand that I bought a coupe of year ago: “Standard” 7mm Copper Core Spark Plug Wire…..100 feet shipped to your door for $48.99.   49 Cents a Foot.  (It was 38 Cents a foot when I bought mine!  Inflation!!!)
                    The quality seems fine to me; I have never had an issue.
                    100-feet
