Home › Forum › Ask A Member › Spark Plug Wire Help
Viewing 3 posts - 21 through 23 (of 23 total)
  • #14702
      The Repco/Phelon Co. was based in Springfield, Mass. USA.
      #14709
      49hiawatha
        Update- Repco/Phelon Co. moved to East Longmeadow , MA and next moved/sold to North Carolina -the land of lawnmowers. Bought out by an international co.
        #14743
        legendre
          quote Moxie man:
          Legendre are you referring to the Arimide? 7mil wire advertised on the O’Reilly parts website?
          Can’t say for sure, the wire I bought there is simply marked "7mm COPPER CONDUCTOR CABLE" in white on the black jacket. No manufacturer’s name or logo that I can see.
          It’s decent material, double-insulated with a white inner core and black outer jacket. There’s also a fiber-mesh layer bonded between the black & white insulation layers, to add mechanical / tensile strength to the insulation. The conductive core is composed of 19 strands of 30 ga. tin-plate copper wire, which if added together approximate a single 17 ga. conductor (1900 circular mils).
          Older cables of this type would normally have fewer strands of larger gauge.. fwiw.
