Home › Forum › Ask A Member › Spark plug info
  • #268766
    Charles Lehmann
      What Champion spark plug is used in a 1947 2hp Evinrude sportsman model 4416 and what is the gap.
      #268768
        The book sez, ’39 – ’47 Sportman motors were equipped with Champion H-10J plugs gapped at .025″.  You’ll have to do some searching to find a modern equivalent to that plug.
        I’m thinking H is the thread length and 10 is the heat range.  J style plugs with the shortened ground aren’t made or needed anymore.
        #268769
        johnny
          Your Sportsman takes an H-10-J spark plug.
          #268777
            Mumbles has it about the H, the 10, and the J.
            The Champion H10C is the closest – easily obtained –
            replacement I know of. It has the 11.2 mm thread
            reach as did the H10C but the end of the ground
            isn’t centered over the electrode. A file can change
            that if one likes.
            #268828
            Charles Lehmann
              Thank you for all your responses.
              #268829
              Charles Lehmann
                Thank you for all your responses on the Sportsman spark plugs.
